Radius arm bushes
13 Sep 2015 16:55 - 13 Sep 2015 16:56 #151907 by Rhinoman
Replied by Rhinoman on topic Radius arm bushes
If the shimmy started after you replaced the kingpins then maybe they need to be shimmed. The castor correction bushes should add some stability, given the issues that the Jimny has I think that Suzuki traded a bit too much stability to lighten the steering.
Last edit: 13 Sep 2015 16:56 by Rhinoman.
18 Sep 2015 14:44 - 19 Sep 2015 04:05 #152192 by Halford
Replied by Halford on topic Radius arm bushes
well the front Suzuki Replacement radius arm to chassis bushes went on yesterday and the front end has tightened up straight away, a lot of the slack feeling has gone, the intergrity of the rubbers in the original bushes actually looked OK but maybe the rubber had deteriorated.
also put on the first set of shims, has helped a little but needs the next size shims on,
will get these on next week. ;)
:woohoo: have found my clonk :ohmy:
it's the universal joint, nothing going to fall off, so will live with it for a while,then replace it along with the Transfer Box Mounting Bushes
wonder when any of our suppliers may be having a sale, only 97 days till christmas :dry:
Last edit: 19 Sep 2015 04:05 by Halford.
  • Tadpole
18 Sep 2015 17:57 #152199 by Tadpole
Replied by Tadpole on topic Radius arm bushes
Some good news Mike ..... ;)
Time to create page: 0.160 seconds
