Rear drive shaft spacer
- Brave
30 Aug 2015 01:53 #150947
by Brave
Rear drive shaft spacer was created by Brave
Rear drive shaft spacer. Do you need to fit one when fitting the jimnybits 3" full lift kit?
I have fitted the supplied spacer between the transfer box and front prop shaft but have been told I need to fit on to the rear also. From your experience is this required when using the HD radius arms.
Big thanks
Big thanks
30 Aug 2015 10:19 #150970
by kirkynut
Replied by kirkynut on topic Rear drive shaft spacer
I ran my Jimny with a 3" lift, no castor correction and no prop spacers for quite some time and had the axles fully twisted up and the shocks at full droop with no issues at all.
So in short, no.
So in short, no.
The following user(s) said Thank You: Brave
- Brave
31 Aug 2015 01:01 #151035
by Brave
Replied by Brave on topic Rear drive shaft spacer
Thanks kirky that's what I though too ill run it and see how it goes
Time to create page: 0.176 seconds
