I've got a Loose feeling gear stick
- NineCherries
26 Aug 2015 12:01 #150667
by NineCherries
I've got a Loose feeling gear stick was created by NineCherries
There seems to be more play in my gear stick than I'd like but only on the left/right plane, forward/back is fine. Is it the nylon bush thingy at the bottom of the gear stick I've read about or is it more likely to be a bush on the selector rods somewhere? I have still to get under and have a proper nosey but it's chucking it down outside at the moment.
Thanks again in advance for your advice.
26 Aug 2015 14:06 #150673
by facade
Replied by facade on topic I've got a Loose feeling gear stick
Could be, or it could be one of the bolts holding the remote linkage together come undone.
At the stick end, there is a ring (with that nylon bush inside) that is held onto the remote shaft by a clamp bolt screwed upwards, I think a plate comes off below the gearlever to tighten it.
The other end of the remote shaft has like a universal joint with two cross bolts, these have top-hat bushes inside.
The following user(s) said Thank You: NineCherries
26 Aug 2015 16:45 #150683
by Halford
Replied by Halford on topic I've got a Loose feeling gear stick
have you tried looking under the gator, it just pulls off without damaging anything, and underneath there's another gator - which if it's come off will make it "feel much slacker" than normal
After my bodylift my stick was very stiff so I had to put "knicks" into the lower gator allowing it to move more freely
just a thought, maybe not a good one, but worth a look
- NineCherries
26 Aug 2015 17:31 #150685
by NineCherries
Replied by NineCherries on topic I've got a Loose feeling gear stick
Cool. Good info, next dry day I'll get underneath and have a good look. At least I'll have an idea what I'm looking for.
Hal, thanks. I'll have a look under the gaiter too
Time to create page: 0.703 seconds
