IG 15A fuse blowing
  • fozzie
01 Sep 2015 18:16 #151129 by fozzie
Replied by fozzie on topic IG 15A fuse blowing
Rufus Ruffcut wrote: Just to let anyone who is interested know.
Ultimately I traced the "short" to the black and white cable taking power to the alternator regulator another cable then takes power back to the battery light. There are seven black and white cables crimped together within the harness, just after it runs through the bulkhead into the engine compartment.
I initially just took the bad cable out of the equation, thinking that having no charge warning light wouldn't be an issue. However on testing the voltage across the battery with the engine running, it appears that the power to the regulator is required for the alternator to charge the battery.
So I have run a new cable to take power down to the regulator and all is now fine!
Thanks again to mickt and Jezz for offering advice!
Well done for finding the fault :)
I've heard that the alternator will fail to work on some cars if the charge light/lamp blows. It appears that the Jimmy is one of those cars.
  • Daniel30
01 Sep 2015 19:20 #151132 by Daniel30
Replied by Daniel30 on topic IG 15A fuse blowing
Excellent well done :)
  • Tadpole
01 Sep 2015 19:55 #151136 by Tadpole
Replied by Tadpole on topic IG 15A fuse blowing
Good find .. ;)
  • mickt
01 Sep 2015 20:31 #151138 by mickt
Replied by mickt on topic IG 15A fuse blowing
Great fault finding skills, well done.
Time to create page: 0.166 seconds
