Good road tyres
  • Daniel30
19 Aug 2015 14:12 - 19 Aug 2015 14:13 #150174 by Daniel30
Replied by Daniel30 on topic Good road tyres
I have 205 75 15 General grabber AT's and I can't fault them B)
Last edit: 19 Aug 2015 14:13 by Daniel30. Reason: added text
  • gusthegorilla
19 Aug 2015 18:35 #150192 by gusthegorilla
Replied by gusthegorilla on topic Good road tyres
Likewise, I run 215/75/15 General Grabbers on my road Jim, and they stick like s**t to a blanket :whistle:
Gus :)
  • fozzie
19 Aug 2015 19:07 - 19 Aug 2015 19:11 #150196 by fozzie
Replied by fozzie on topic Good road tyres
Well it's been raining here since about 15:45. Took Jimny out for a test when I got home from work. Braked at a random part of the road (nobody behind obviously), pressed the brake pedal a little harder as It slowed to about 10mph, the abs cut in. Can also easily spin the rear wheels when pulling away urgently!
Even though there's plenty of tread on them, these tyres have definitely seen better days :(
I've looked at the grabbers, and pictures of Jim's with them on. They really look good, tyres on steroids :lol: If you like them they must grip in the wet on normal roads.
Will 205/75 15 grabbers fit my standard Jim without rubbing anywhere, or do they only fit lifted Jims?
Last edit: 19 Aug 2015 19:11 by fozzie. Reason: took word out
  • gusthegorilla
19 Aug 2015 19:14 #150197 by gusthegorilla
I had to remove my 2 x front mud flaps, that was all (it's not lifted)
Gus :)
19 Aug 2015 19:32 #150198 by jackonlyjack
  • Daniel30
19 Aug 2015 19:45 - 19 Aug 2015 19:46 #150200 by Daniel30
fozzie wrote: Well it's been raining here since about 15:45. Took Jimny out for a test when I got home from work. Braked at a random part of the road (nobody behind obviously), pressed the brake pedal a little harder as It slowed to about 10mph, the abs cut in. Can also easily spin the rear wheels when pulling away urgently!
Yes can't see why not, I haven't got a lift on mine only -30 offset wheels but I don't think that would make a difference B)
But like jackonlyjack has mentioned check air pressure aswell
Last edit: 19 Aug 2015 19:46 by Daniel30. Reason: added text
Time to create page: 0.216 seconds
