very loud tapping noise from the engine
- mickt
27 Jul 2015 18:10 #148525
by mickt
Replied by mickt on topic very loud tapping noise from the engine
With the engine running you could listen to the noise using something like a long screwdriver pressed against the block and your ear to the top of it. Generally a small end will be noisy all the time whereas a big end will make most of its racket under load. Why do you want to access the bottom end? If it is the/a small end then the piston and rod will need to come out through the top. You could get all the bolts of the sump off but whether it will angle enough to clear the oil pickup is another thing.
- mark 88
27 Jul 2015 20:45 #148542
by mark 88
Replied by mark 88 on topic very loud tapping noise from the engine
its in a 2003 soft top think we talking dealer parts so i think an other engine in order. is there a difference in variant between hard and soft top? also will my ECU run a new engine? thanks all
- Olucas91
27 Jul 2015 21:33 #148545
by Olucas91
Replied by Olucas91 on topic very loud tapping noise from the engine
If your sourcing a new engine why not fit a 1.6?
28 Jul 2015 06:22 #148566
by j999pre
Grey pick up Jimny
Replied by j999pre on topic very loud tapping noise from the engine
Your soft top will have a different cam pick up ring on the back of the cam, a different sump and different inner crank pulley to trigger the crank sensor. The early hard tops don't have these but all parts are interchangeable. So if you got an early g13b you would need to swap sump, cam or just the ring, inner crank pulley and drill an 18mm hole for the crank sensor. Its all easy stuff. I think there is a g13b hard top engine on eBay
Grey pick up Jimny
- mark 88
28 Jul 2015 15:08 #148581
by mark 88
i was tempted at a 1.6 but i need to get the jeep going again as fast as possible where on the engine can i find identifying marks ? thanks all
28 Jul 2015 16:14 #148587
by j999pre
Grey pick up Jimny
Look under the car up at the crank pulley just in the sump should be the crank sensor
Grey pick up Jimny
Time to create page: 0.812 seconds
