jimny shuddering when setting off on a hill
14 Jul 2015 08:01 #147739
by kirkynut
Replied by kirkynut on topic jimny shuddering when setting off on a hill
Could this be old fashioned clutch judder?
Caused by an overheated clutch at some point. Do you ride the clutch in traffic?
14 Jul 2015 08:13 #147742
by gilburton
Replied by gilburton on topic jimny shuddering when setting off on a hill
My Jimny (08)has had a slight judder for years when it is starting from cold.
After the engine gets warmer and the clutch has been used a few times it disappears.
The clutch isn't worn.
I wasn't bothered about it and was leaving it until the clutch needed replacement but so far it doesn't need it.
Just as a matter of interest how much movement should there be on the transfer box mountings?
- susie
15 Feb 2016 21:23 #162453
by susie
Replied by susie on topic jimny shuddering when setting off on a hill
How do you know if gear box need replacing? I was told by one mechanic it needed doing and another one said it didnt need doing. Its been a year. Is there a way to tell it needs doing?
16 Feb 2016 11:54 - 16 Feb 2016 12:00 #162487
by gilburton
If it drives normally with no whines and engages gears with no noises it's not the gearbox.
Juddering,as others have said, is usually either the clutch or the rear engine mount.
I had my clutch done recently and the judder that I used to get when the car was cold is now gone.
It is possible that the juddering has now allowed the rear engine mount (gearbox mount) to get worse and is causing your knocking noise on the other post??
Last edit: 16 Feb 2016 12:00 by gilburton.
16 Feb 2016 12:05 #162489
by gilburton
Now take this info with a pinch of salt but as you are near here can you not pop along to these people and ask if they can recommend anyone?? I don't think they would do it themselves as they are a Jimny breaker but you never know??
www.camsuzuki.com/About-Us/
- susie
16 Feb 2016 12:10 #162490
by susie
Thanks! I will contact them
Time to create page: 0.635 seconds
