ABS jimny with non ABS wheel bearing compatibility
  • Steveolkinevel
28 Jun 2015 20:16 #146807 by Steveolkinevel
As title realy, will non abs wheel bearings fit abs hubs? I'm ditching the abs as it's not working anyway and the non abs bearings are sooooo much cheaper.
Thanks in advance
28 Jun 2015 20:37 #146809 by mlines
The bearing is the same, its the retaining ring that is different. If you are ditching the ABS then the other bearings will fit.
I assume you have seen my ABS wheel bearings at £65 which is cheaper than a lot of places.
  • Steveolkinevel
28 Jun 2015 21:02 #146814 by Steveolkinevel
Replied by Steveolkinevel on topic ABS jimny with non ABS wheel bearing compatibility
Hi thanks for your reply, yea I have Martin but I just can't be bothered replacing the sensors and pump so just doing without it, it's not a daily so not an issue, plus non abs are only £15 so can order a few as spares.
Thanks
03 Jul 2015 13:33 #147122 by safari
hi you will be needing the retaining ring which is different from non abs , i tried to find it alone and could not
if u worry u die if u dont worry u still die so why worry
The following user(s) said Thank You: Steveolkinevel
Time to create page: 0.447 seconds
