handbrake adjustment
- oxford_bloke
15 Jun 2015 17:15 #146020
by oxford_bloke
handbrake adjustment was created by oxford_bloke
I have a muddy zook rear brake conversion and when I pull on the handbrake only one wheel locks up. I have had it on jacks for the last 2 hours trying to work this out. With the caliper leaver all the way over the wheel still doesn't appear to lock up is this an internal problem within the caliper? Or am I missing something obvious?
15 Jun 2015 18:02 #146026
by j999pre
Grey pick up Jimny
Replied by j999pre on topic handbrake adjustment
Can you adjust the piston in that caliper out a bit so that the movement you get is enough to stop you? If not sounds like a caliper issue
Grey pick up Jimny
- oxford_bloke
15 Jun 2015 18:05 #146027
by oxford_bloke
Replied by oxford_bloke on topic handbrake adjustment
how would i go about adjusting the piston out? would it not pop out when driving it when breaking?
15 Jun 2015 18:36 #146030
by j999pre
Grey pick up Jimny
If you have a lot of clearance between the pads and the disc then you can adjust the piston out to take up the clearance, then when you pull the cable it should grip the disc and no it won't pop out. If the piston isn't moving at all then it's probably a caliper problem
Grey pick up Jimny
- oxford_bloke
15 Jun 2015 18:46 #146033
by oxford_bloke
nice one thank you any idea on how to do this on rover 200 calipers?
- Thank you received: 680
15 Jun 2015 19:01 #146043
Replied by jackonlyjack on topic handbrake adjustment
the piston should screw in and out
it's not like front wer it slides back n forth
Jack
Jack
Time to create page: 0.713 seconds
