Uprated CVS and shafts
22 May 2015 06:25 #144620 by X8GGY
Replied by X8GGY on topic Uprated CVS and shafts
Jezz wrote: Rockwatt, if you don't mind. Knowing this is your field. Do you have a preference for 22 or 26 spline shaft, Or doe's it not matter a great deal?
Jezz wrote: I should just say, I'm not trying to put you on the spot. I'm just interested in your thoughts on the big shaft small shaft, 2 pin 4 pin big spline etc argument.
Oooh, waiting with baited breath... :woohoo:
  • bluejimny
22 May 2015 07:50 #144628 by bluejimny
Replied by bluejimny on topic Uprated CVS and shafts
i went for 26 spline as ive seen a std front jimny diff that has failed.
im going to get a jimny rear ARB drop it into the front, saves getting 26 spline sides for a jimny front.
with all the CV's shafts and diff strengthened, it will just pass to the next weakest point, which will prob be the front prop or ring and pinion gears (as i have also sheared the teeth of a ring gear) but this was the rear axle though
22 May 2015 08:50 #144631 by X8GGY
Will you be only offering 26 spline shafts through JimnyBits then Rus?
  • TomDK
22 May 2015 09:01 #144634 by TomDK
Replied by TomDK on topic Uprated CVS and shafts
bluejimny wrote: i went for 26 spline as ive seen a std front jimny diff that has failed.
with all the CV's shafts and diff strengthened, it will just pass to the next weakest point, which will prob be the front prop or ring and pinion gears (as i have also sheared the teeth of a ring gear) but thi out s was the rear axle though
What about warranty Rus?
I know that RCV offers warranty on all their shafts and joints.
  • TomDK
22 May 2015 11:47 #144644 by TomDK
Jezz wrote: So that begs the question, why are they making both if Tomdk claims the 22 spline are superior?
I only claim them to be superior to 26 splines from RS.
26 splines shafts vs 22 splines both from RCV, I'm pretty sure the 26 splines would be a bit stronger :)
  • ilten
23 May 2015 14:40 #144707 by ilten
Replied by ilten on topic Uprated CVS and shafts
And how are you going to accomplish this? As a rear Jimny / Samurai diff is a lot bigger than a Jimny front??? I have ARBs front and rear, and if you want to use 26 spline you will have to get 26 spline side gears for a rear ARB and machine the collar on the gear so it fits in the front. It can be done, but it's tricky.
Time to create page: 0.537 seconds
