Uprated CVS and shafts
21 May 2015 17:29 - 21 May 2015 17:30 #144580 by X8GGY
Replied by X8GGY on topic Uprated CVS and shafts
Rhinoman wrote:
Jimny-Dave wrote: front LSD... 2 pin or 4 pin I thought?
Then I read - www.bits4vits.co.uk/lsdfsm.pdf (this is the manual for the rear, but I suspect the front is the same?)
That looks like a solid + cross in the middle?
How strong is that in relation to 2 and 4 pin diffs? :blink:
Dave
The stock Vitara front diff is a two-pin, when fitting a locker a four-pin Samurai rear is a common upgrade.
Edit: here is a good link:
www.zukikrawlers.com/showthread.php?t=4215&page=2
But the FSM shows a solid piece in the middle? -
Last edit: 21 May 2015 17:30 by X8GGY.
21 May 2015 20:24 #144598 by kirkynut
Replied by kirkynut on topic Uprated CVS and shafts
Ah, so the ones that you plan to sell are 26 spline then Russ? That changes things a bit.
  • Rockwatt
21 May 2015 21:27 #144606 by Rockwatt
Replied by Rockwatt on topic Uprated CVS and shafts
Dave
Your front diff is a 4pin 26 spline Dave
21 May 2015 22:27 #144611 by Jezz
Replied by Jezz on topic Uprated CVS and shafts
Rockwatt, if you don't mind. Knowing this is your field. Do you have a preference for 22 or 26 spline shaft, Or doe's it not matter a great deal?
It's been fettled just a tad.
21 May 2015 22:53 #144615 by Jezz
I should just say, I'm not trying to put you on the spot. I'm just interested in your thoughts on the big shaft small shaft, 2 pin 4 pin big spline etc argument.
22 May 2015 06:24 #144619 by X8GGY
Rockwatt wrote: Your front diff is a 4pin 26 spline Dave
Thanks Rockwatt B) Confirmation from the God of Gearing that mine's the best of both worlds then? ;)
(Rockwatt should know what spec' my diff is, as he machined it to fit in a Jimny carrier for me :kiss: )
Dave :laugh:
Time to create page: 0.510 seconds
