The Mystery of the Horn that doesn't hoot.
04 Apr 2015 00:57 #141877 by facade
Stebel don't have the best reputation.
I fitted a stebel Magnum to mine. It worked 3 times in 2 years (once to test and then at 2 MOTs) then took some persuading to work at the 3rd MOT, so I found the original "beep beep" horn and put that back.
Sounds like Noddy's car again, but it works B)
04 Apr 2015 05:54 #141878 by Lambert
My beeper is used a lot to encourage recalcitrant sheep and it failed a year or so back turned out one of the wires at the connection plug had snapped, one new spade connection and all is good.
04 Apr 2015 11:38 #141895 by facade
If you get too enthusiastic tooting on your little horn :whistle: the switch inside the steering wheel can burn out.
  • helijohn
04 Apr 2015 19:04 #141912 by helijohn
Replied by helijohn on topic The Mystery of the Horn that doesn't hoot.
facade wrote: If you get too enthusiastic tooting on your little horn :whistle: the switch inside the steering wheel can burn out.
I like to have a second horn wired to a dash mounted button switch. ;) There is no real room in the Jimny for a big horn set up.
locomotivehorns.info/5chime.jpg
04 Apr 2015 22:41 #141922 by kirkynut
I have a Klaxon Arooogah horn wired in separately with a push button switch under my steering wheel.
I use it when someone cuts me up etc. It's so funny it could never start a fight or get anyone angry by being used aggressively, so I can get away with giving lots of poor drivers the horn - so to speak!
  • helijohn
04 Apr 2015 22:45 #141923 by helijohn
kirkynut wrote: It's so funny it could never start a fight or get anyone angry by being used aggressively, so I can get away with giving lots of poor drivers the horn - so to speak!
It's the trucks and heavies that I find a need for a blasting horn for. :angry:
Time to create page: 0.219 seconds
