Fitting AVM manual hubs
  • Lozi
29 Mar 2015 21:06 #141603 by Lozi
Replied by Lozi on topic Fitting AVM manual hubs
j999pre wrote: Avm jimny manual hubs don't need spacers. They should come with new bolts, Allen head ones from memory.
Are they definitely avm brand and for a Jimny or have you got sj hubs? In which case you do need spacers and bolts with cone washers.
They are jimny ones from jimnybits, I have emailed them and they said they are meant to come with bolts so they are sending some out to me :)
  • Lorry
30 Mar 2015 11:18 #141628 by Lorry
Replied by Lorry on topic Fitting AVM manual hubs
Well I stand corrected I thought all the fwh needed spacers.
30 Mar 2015 12:35 #141631 by facade
Replied by facade on topic Fitting AVM manual hubs
The spacers are because the seal shoulder on the hub nut sticks out.
The "special" jimny ones are deeper at the back to miss this shoulder.
Standard FWH as removed from an SJ, or new to fit an SJ will foul on the shoulder and require a spacer.
You can grind off the shoulder, but that makes you cry, as new shouldered nuts are about £2000 each :(
30 Mar 2015 15:10 #141639 by Lambert
Replied by Lambert on topic Fitting AVM manual hubs
And fitting a spacer also reduces the contact area between the hub and the drive shaft which is increasing the liklihood of failure.
Time to create page: 0.144 seconds
