Abs rear wheel bearing size.
10 Mar 2015 20:40 #140328 by Jezz
Hi all, Can someone confirm the rear wheel/half shaft bearing size for me. I know it's 72 outer x 35 inner,
It's the depth i need to confirm.
Thank you.
It's been fettled just a tad.
10 Mar 2015 23:15 #140339 by kirkynut
I'd just buy from the Bigjimny shop and not worry about it. It has to be the cheapest place.
10 Mar 2015 23:47 #140342 by Jezz
Replied by Jezz on topic Abs rear wheel bearing size.
I don't need a new one, I just want to confirm the depth, without going to the hassle of pulling a shaft to measure.
11 Mar 2015 07:07 #140345 by mlines
Replied by mlines on topic Abs rear wheel bearing size.
The bearings themselves are the same across the old SJ and the Jimny vehicle ranges whether they are ABS or not.
It is DG357222DWC4
www.noc.ua/en/online-catalog-bearings/it...DG357222DWC4&key=722
The following user(s) said Thank You: Jezz
11 Mar 2015 08:19 #140351 by Jezz
Thank you Martin that's just what I was after. B)
11 Mar 2015 10:21 #140357 by safari
Replied by safari on topic Abs rear wheel bearing size.
the bearings r the same only the collar for abs is different thats what i fit .mine is abs
if u worry u die if u dont worry u still die so why worry
Time to create page: 2.034 seconds
