can i tighten up my steering box
05 Mar 2015 16:59 - 05 Mar 2015 17:00 #139948
by kirkynut
Replied by kirkynut on topic can i tighten up my steering box
As mentioned above, there is a large flat head screw with a lock nut on it. I have adjusted mine and did the same on my SJ but you really need to be careful so as not to make it too tight. Make sure the steering is straight ahead when adjusting it and only tighten it tiny amounts at a time. Then turn the steering lock to lock and you should not feel any notchiness at all, not even the slightest.
If you have notchiness after adjusting, back it off a bit and try again.
There will be proper guidance on a repair/maintenance CD, which you can get cheaply online: www.bigjimny.com/index.php/forum?view=topic&catid=7&id=5264
Last edit: 05 Mar 2015 17:00 by kirkynut.
- mark 88
06 Mar 2015 08:32 #139988
by mark 88
Replied by mark 88 on topic can i tighten up my steering box
great stuff thanks all will give it a crack
- mickt
18 Mar 2015 20:33 #140891
by mickt
Replied by mickt on topic can i tighten up my steering box
Mark88 Any feedback on your box adjustment i.e. did it work? Any feedback is useful to other members, it what makes the forum tick!
- Steveolkinevel
19 Mar 2015 00:26 #140911
by Steveolkinevel
Replied by Steveolkinevel on topic can i tighten up my steering box
Yes this works, my jim isn't scary to drive any more no play in steering, realy easy to do to.
Steve
Steve
19 Mar 2015 01:02 #140913
by kirkynut
Just be sure not to over tighten it.
If you lack the front axle up so both wheels are off the ground and turn them by pushing on a road wheel, you shouldn't feel any notchiness. Similarly turning lock to lock on the ground.
