can i tighten up my steering box
  • mark 88
04 Mar 2015 20:12 #139870 by mark 88
can i tighten up my steering box was created by mark 88
hi all i have slight play in my steering box which i believe is causing my death wobble . old vw beetles have a steering box and im told that you can tighten them up by slackening of a lock nut and using a flat top screwdriver adjust them.
i found a similar setup on my jimny but before i start fiddling i thought id ask for info first
thanks all
  • mickt
04 Mar 2015 20:28 #139872 by mickt
Replied by mickt on topic can i tighten up my steering box
Have you got power steering?
  • mark 88
04 Mar 2015 21:42 #139884 by mark 88
Replied by mark 88 on topic can i tighten up my steering box
yeah
  • mc_nebula
05 Mar 2015 01:10 #139907 by mc_nebula
Replied by mc_nebula on topic can i tighten up my steering box
im interested in this too....
  • mark 88
05 Mar 2015 08:37 #139916 by mark 88
well i run 235/75/15 tyres so as they are quite heavy so the steering box must take a fair pounding with them
  • mickt
05 Mar 2015 14:34 #139939 by mickt
According to my dvd maintenance manual there is an adjustment screw under the manual gearbox section which is mentioned in the power steering section as for compensating for wear in the output part of the box. It details using a pull of spring balance to measure the resistance before and after turning the adjuster. I reckon if you just crack the lock nut and turn the slotted screw head say half a turn in and see if it makes any difference it should not do any harm. Do not forget to relock the lock nut. You could always go back to original position. It is a mechanical adjustment meant to take up the slack/wear in the cam and worm of the box.
