Wonky wheel spacers. One side pokes out more?!?!
  • davert85
02 Mar 2015 17:19 #139623 by davert85
Hello all,
I fitted some 2nd hand 32mm wheel spacers the othet night, simple job and all seemed to go to plan. However....the next day in better light i noticed the right hand side sticks out noticeably more than the left?
Anyone know why this may be? Its both wheels in the right. Can the body shift with all the abuse iv given the jim? Axles twist? Spacers aint fitted right? Im clueless.
Any help would be great
Thanks.
02 Mar 2015 17:29 #139629 by Busta
If you've lifted it but still have standard panhard rods the axles will be off centre.
The following user(s) said Thank You: davert85
  • davert85
02 Mar 2015 17:36 #139630 by davert85
Busta wrote: If you've lifted it but still have standard panhard rods the axles will be off centre.
Oh so that could be or is my issue. Iv got a 2" lift kit, i assume thats enough to cause it?
  • helijohn
02 Mar 2015 17:47 #139633 by helijohn
Many of my chassis based 4x4s (in fact most) have sat slightly to one side. It becomes noticeable when wide wheels are fitted or as in your case spacers. The visual clues become more apparent when the tread or such lines up with the arch or something. I have a 1cm difference even now on my Pinin.
02 Mar 2015 18:05 #139635 by mlines
Incorrect panhard rod length after a lift pulls the body a few mm to one side.
  • davert85
02 Mar 2015 18:39 #139638 by davert85
Cheers guys. I think mine is visually so noticeable as iv done a fair bit of trimming so you can see a lot more tyre anyway. Even so, one side is considerably more than the other. I do love how much the waider side sticks out, i hope the new pans wont take to much away ;) haha
Time to create page: 0.159 seconds
