Towbars/Towballs
- Paul_sterling
27 Feb 2015 10:55 #139315
by Paul_sterling
Replied by Paul_sterling on topic Towbars/Towballs
champion, sounds exactly the same as the transit connect, side plates followed by rear crossmember, then tighten up, the bars even look the same.
I do still have the old vitara towbar, but I very much doubt that would fit, and for the cost of a new one, theres not much point trying lol.
Paul.
Paul.
27 Feb 2015 11:05 #139316
by gilburton
Replied by gilburton on topic Towbars/Towballs
Yeah the cheaper fixed flange ones are usually around the £100 mark but removable ones are not much more if you avoid the genuine Suzuki of course lol
It's up to you which one you buy and how worried you are about the tiny amount the towball covers the number plate.
Plenty of Jimny pics on the net with towbars fitted so you can judge yourself.
Good luck
Good luck
27 Feb 2015 11:20 #139317
by gilburton
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is just for illustration. I can't see the small plates /tabs with nuts welded on that slide in to the hollow chassis but most towbars follow the same principle.
The following user(s) said Thank You: Paul_sterling
- Tadpole
27 Feb 2015 19:17 #139359
by Tadpole
Replied by Tadpole on topic Towbars/Towballs
380/15" ........... hth ..........Paul_sterling wrote: thanks Tadpole, what height does the top of your towball sit at?
Paul.
- Paul_sterling
04 Mar 2015 12:35 #139823
by Paul_sterling
I've ordered a tow trust towbar, the flange type, but is removable with the two underside bolts.
I prefer this over the swan neck, as for the most part, it can be stored inside the vehicle, and I can have a stainless steel guarding plate fitted on it to stop an over enthusiastic trailer damaging the car.
lastly, if the hitch height is too low, there is a degree of adjustment with this design, whilst staying within the letter of the law.
Collecting the car tomorrow, so should be able to fit this at the weekend.
Spoke to Suzuki, and they confirmed that the car does not need a bypass relay, which simplifies things somewhat, not to mention, reduces the build cost.
Paul.
Paul.
Time to create page: 0.436 seconds
