Ahhhhh,Check Engine light on :o
  • gembrand
17 Feb 2015 12:43 #138189 by gembrand
Replied by gembrand on topic Ahhhhh,Check Engine light on :o
Hi,
No idea why but the Check Engine light has gone off all on it's own,so hopefully okay.
Pretty sure calliper is sticking going to get that sorted,so thanks again everyone for your help :o)
  • Grego
17 Feb 2015 17:31 #138203 by Grego
Replied by Grego on topic Ahhhhh,Check Engine light on :o
Mine came on and off a couple of times so I bought a Maxiscan reader off ebay for £12, read the code and then cancelled it (cant remember the actual code but it was the throttle body) cleaned the throttle body out in 15mins and I havent seen the light since.
All thanks to the help I got from the peeps on here :)
Well worth the £12 too
17 Feb 2015 19:22 #138238 by Rhinoman
A Y plate Jimny is probably not OBD2, you would need to check the diagnostic connector to see which pins are populated.
  • Paul_sterling
17 Feb 2015 22:28 #138264 by Paul_sterling
Replied by Paul_sterling on topic Ahhhhh,Check Engine light on :o
gembrand wrote: Thanks for the info,not a good start is it,at least l found the bonnet release,lol,so you think l should ring the dealer,okay
All the levels appear to be okay,it runs fine so can't be too bad,fingers crossed :o
absolutely, even if code light has gone out, the fault will be stored, and simply put, why should you pay dealer prices for a car only for it to produce a fault within a week.
from my experience, the C.E.L most likely offenders, are the lambda sensor, or MAF, though other issues do crop up too.
Paul.
18 Feb 2015 19:11 #138343 by Rhinoman
It doesn't have a MAF so its not likely to be that. Even if its OBD1 fault codes are stored but need an OBD1 tool to be read.
  • troggy
18 Feb 2015 19:16 #138344 by troggy
Replied by troggy on topic Ahhhhh,Check Engine light on :o
I think lambda sensors can cause check engine light. Mine used to come and go off, but didn't worry about it much. Easier to listen, feel and smell for problems. The light could be any random thing.
Time to create page: 0.176 seconds
