Ahhhhh,Check Engine light on :o
  • gembrand
16 Feb 2015 23:55 #138165 by gembrand
Ahhhhh,Check Engine light on :o was created by gembrand
Hi,
Had this Jimny for a day and the Check Engine light has came on,when you step outside the car there's a burning smell,not happy :o(
Bought it from a dealer in Newark on Sunday,think he's sold me a dud !
  • jim
17 Feb 2015 00:12 - 17 Feb 2015 00:13 #138166 by jim
Replied by jim on topic Ahhhhh,Check Engine light on :o
Have you checked the oil and coolant levels?
Last edit: 17 Feb 2015 00:13 by jim. Reason: error
  • jim
17 Feb 2015 00:22 #138167 by jim
The burning smell might be from what you described in your last post sounding like a binding brake caliper.
I hope you get it all sorted and have a more positive start to your new jim ownership.
  • Paul_sterling
17 Feb 2015 08:20 #138170 by Paul_sterling
Replied by Paul_sterling on topic Ahhhhh,Check Engine light on :o
take the car straight back. a genuine dealer is obliged to offer a warrantee on vehicle sales, the minimum as I recall is 3 months.
you can manually test the C.E.L. but I don't know where the plug is on a Jimny.
on the Vits, you could insert a wire across two points of the plug, and the C.E.L would flash a code to you, which could be cross referenced with the Haynes manual/and or other suitable manual to identify what the fault was.
Paul.
  • gembrand
17 Feb 2015 08:35 #138172 by gembrand
Replied by gembrand on topic Ahhhhh,Check Engine light on :o
Thanks for the info,not a good start is it,at least l found the bonnet release,lol,so you think l should ring the dealer,okay
All the levels appear to be okay,it runs fine so can't be too bad,fingers crossed :o
  • Russ-41
17 Feb 2015 08:45 #138174 by Russ-41
Replied by Russ-41 on topic Ahhhhh,Check Engine light on :o
If one of your calipers is binding to the extent that you can smell it, one of your wheels will be hotter than the rest after a reasonably lengthy drive (20mins+?). Check carefully from the outside near the tyre inward, it could be hot enough to burn you at the centre where it connects to the brake disk so go easy.
Time to create page: 0.308 seconds
