steering knuckle oil seal, bearing gasket.
- benkri1992
07 Jan 2015 15:00 #134415
by benkri1992
steering knuckle oil seal, bearing gasket. was created by benkri1992
- Thank you received: 923
07 Jan 2015 15:02 #134417
Replied by X8GGY on topic steering knuckle oil seal, bearing gasket.
I followed Martin's excellent guide -
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
when I rebuilt my front axle...
07 Jan 2015 15:04 #134418
by safari
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic steering knuckle oil seal, bearing gasket.
hi num 3 is the oilseal and if i am not wrong if it is gone chq also king pins for exasive play they do not wear alone
07 Jan 2015 15:07 - 07 Jan 2015 15:09 #134419
Strange schematic, as it appears to show a manual free wheel hub, not the vacuum operated hub you would expect on a Jimny...?
Last edit: 07 Jan 2015 15:09 by X8GGY.
07 Jan 2015 15:37 #134425
Replied by mlines on topic steering knuckle oil seal, bearing gasket.
Daves correct, that looks like an SJ diagram as it also has the felt pads in it
The following user(s) said Thank You: benkri1992
- benkri1992
07 Jan 2015 17:48 #134448
by benkri1992
Replied by benkri1992 on topic steering knuckle oil seal, bearing gasket.
hmm, okey. but my problem is that its leaking oil in to the knuckle house.
and i am change the seal. does anyone have the right drawing for the jimny then ?
Time to create page: 2.472 seconds
