Seatbelt adjuster removal
- Thank you received: 360
19 Nov 2014 16:06 - 19 Nov 2014 16:08 #130022
by Halford
Seatbelt adjuster removal was created by Halford
I want to take the up/down driver side Seatbelt adjuster off to modify/clean,
does anyone know how it comes apart, does the B Pillar trim have to be removed? (how?) :huh:
I'm sick of the belt sticking and not rewinding smoothly, everything is fine except for the pesky little slot that needs making bigger.
would they're be any MOT issues if I dremmelled a bit out - extreme I know, but function over finesse and it wouldn't impact on safety - or would it - apart from loosing fingers on the dremel :pinch:
thanks for any help/MOT tester comments
Last edit: 19 Nov 2014 16:08 by Halford.
19 Nov 2014 16:21 #130025
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Seatbelt adjuster removal
Trim on belt clip lifts up, 14mm bolt
Side trim pulls off then 2 bolts behind
Grey pick up Jimny
19 Nov 2014 16:29 #130026
by Halford
:huh: thanks James, but having a dim moment, could you clarify
Replied by Halford on topic Seatbelt adjuster removal
j999pre wrote: Trim on belt clip lifts up, 14mm bolt
- jonesyba420
19 Nov 2014 17:14 #130035
by jonesyba420
Replied by jonesyba420 on topic Re:Seatbelt adjuster removal
The bit where your red lines are lifts up to reveal the 14mm bolt.
19 Nov 2014 17:54 #130043
by Halford
- jonesyba420
19 Nov 2014 18:01 #130045
by jonesyba420
Replied by jonesyba420 on topic Seatbelt adjuster removal
Yep, sanded mine down a bit a while back helped abit;)
Time to create page: 0.424 seconds
