Lift kit from OEM parts
  • minitehnicus
04 Nov 2014 18:35 #128486 by minitehnicus
Replied by minitehnicus on topic Lift kit from OEM parts
ME13OSE wrote: Has anyone been successful in lifting a jimny 2 inch or greater on standard parts from other vehicles?
on my street jimny i have this setup.
rear axle.
-jimny front springs. they are 2 inch longer and have the same stiffness as the rear one, 120 lbs/inch.
-KYB 343098, rear lada niva shocks, closed/opened=310mm/505mm
front axle
-lada samara rear springs. eg: TRW JCS495, ROC CS5503. they have 425mm length and around 110lbs/inch
KYB 443031, rear opel rekord shocks, closed/opened=310mm/525mm
the front suspension is a little bit soft but i can live with it. the rear is fine.
ME13OSE wrote: Blind old dog spoke about CRV parts in 1 of his threads a while back but some of the part numbers don't match up with Uk spec vehicles.
the spring are from Honda CR-V 2.0 16v (RD1 or RD3)
Monroe SP3484
TRW JCS396
ROC CS4150
take a look at the russian suzuki forum and you will find all the info.
i don't know russian, but read it with google translate.
  • ME13OSE
08 Nov 2014 11:17 #128878 by ME13OSE
Replied by ME13OSE on topic Lift kit from OEM parts
Thanks for everyone's input, I full understand the mechanics and science behind it all, and know what parts require changing for a lift. And although essentially I do have an entire warehouse of pretty much every shock/spring for the cars in the UK I don't have the time to trawl through them all, or test fit each unit. Hence the reason I asked the question.
It would appear that all you get off most of the users of this forum is "building my jimny on a budget" and moaning about the price of good quality workmanship so I thought at least a few folk might have given it a go and found a formula that works.
Time to create page: 1.475 seconds
