Headlights ON sound
  • Tasscorp
23 Oct 2014 01:24 #127263 by Tasscorp
Headlights ON sound was created by Tasscorp
Hi guys,
Simple question. Does the 2000 Jimny has the tipical sound when you left the headlights on ?? Mine doesn't and I keep leaving them on !!!
Thanks
Marcelo
  • ZookFastback
23 Oct 2014 01:35 #127264 by ZookFastback
Replied by ZookFastback on topic Headlights ON sound
Yep, it has a very annoying and persistent sound. :pinch:
  • Tasscorp
23 Oct 2014 02:16 #127265 by Tasscorp
Replied by Tasscorp on topic Headlights ON sound
Thanks for that. I'll have to check why mine is not working. Any ideas where to look at ?
  • parriehunter
23 Oct 2014 02:35 #127266 by parriehunter
Replied by parriehunter on topic Headlights ON sound
Does the key in the ignition with the door open beep? If not the car may not know that the door is actually open. there is plug on the plastic trim behind the door that i am having problems with that may be causing the issue.
  • Tasscorp
23 Oct 2014 02:51 #127267 by Tasscorp
Nope, it doesn't beeps either
  • NineCherries
23 Oct 2014 08:37 #127271 by NineCherries
Replied by NineCherries on topic Headlights ON sound
Does your interior light come on when you open the door (and have the interior light switch in the correct position)?
If not check if there is a door switch (this advice comes from a tech savvy guy not a jimny owner, yet, so I don't know if the switch is obvious or not)
Time to create page: 0.311 seconds
