Steering wheel not straight after lift ?
  • Vinnie
10 Sep 2014 16:47 #123810 by Vinnie
I've just fitted a 2.5 lift kit with correction bushes in front arms took it for a test ride now the Steering wheel isn't straight how can this be ??
New springs/shocks wheels and tyres has nearly cured the wobble but can't understand why wheel not straight ??
Cheers vinnie
10 Sep 2014 17:54 - 10 Sep 2014 17:59 #123816 by facade
The axle is lower down, so the drag link (from steering box to axle) is now too short, so you need to turn the wheel to put the steering straight.
You will have more steering lock on one side than the other.
Lengthen the drag link until the wheel is straight again.
EDIT: you didn't mention panhard rod, that will be too short too, displacing the axle to one side. When you lengthen the panhard rod, the drag link will want setting again.
Last edit: 10 Sep 2014 17:59 by facade.
The following user(s) said Thank You: Vinnie
  • GuardianAngel
10 Sep 2014 18:03 #123817 by GuardianAngel
Replied by GuardianAngel on topic Re:Steering wheel not straight after lift ?
Useful info that. Another job I need to do. My Jimny job list is getting bigger :'(
  • Vinnie
10 Sep 2014 18:27 #123819 by Vinnie
Replied by Vinnie on topic Steering wheel not straight after lift ?
facade wrote: The axle is lower down, so the drag link (from steering box to axle) is now too short, so you need to turn the wheel to put the steering straight.
Ok cheers for that think I get what ya mean cause the panhard rod is fixed to chassis one side and axle the other cause of lift its pushed the axle over to one side causing the steering arm to go also ? If I fit an adjustable panhard arm it will push axle back over along with steering ? Will I need to get the tracking adjusted though ?
So I need a panhard if anyone got one
Cheers vinnie.
  • Vinnie
10 Sep 2014 19:18 #123829 by Vinnie
So if I just lengthen the drag link won't the axle still be out line ?
Cheers vinnie
10 Sep 2014 20:13 #123834 by dirtydogz
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Time to create page: 1.543 seconds
