lenth of belts
  • Butta
15 Aug 2014 11:09 #122093 by Butta
lenth of belts was created by Butta
Hi anyone have the correct belt lenths (fan and pas belts) for a 2004 twin cam jimny without a/c dont want to pay main stealer prices and motor factors by me say they are same lenth which I know is wrong also ebay is just confusing. Thanks in advance....
15 Aug 2014 12:43 #122100 by facade
Replied by facade on topic lenth of belts
Open the bonnet and look at the belts, the size is printed on the plain side eg 4pk850 means 4 ribs 850mm long, it is the only way to be sure you get the right one.
If you have run out of adjustment, get one slightly smaller.
I think I bought 4pk850 and 4pk830 for my 2001.
The following user(s) said Thank You: Butta
  • Butta
15 Aug 2014 13:07 #122101 by Butta
Replied by Butta on topic lenth of belts
facade wrote: Open the bonnet and look at the belts, the size is printed on the plain side eg 4pk850 means 4 ribs 850mm long, it is the only way to be sure you get the right one.
cant read mine if yours is 2001 hard top it will be twin cam the same
  • Butta
15 Aug 2014 13:18 #122102 by Butta
Just about managed to read fan belt which is 4pk 835 but im sure 4pk 830 would be fine just need to find pas belt lenth anyone able to read their belt pls (post 2001 twin cam with cam chain and no air con)
  • Butta
15 Aug 2014 14:02 #122105 by Butta
Ok have been told oem belts are 4pk836 and 4pk813 anyone confirm this is correct? If it is I can save £30+ from main stealer prices!
15 Aug 2014 15:36 #122108 by facade
I've been and had a look outside. My old power steering belt was 860, but it ran out of adjustment, so I fitted an 850, I bought an 836 for the alternator, there is an 835 on it now, and the adjustment is about half way.
