amada Extreme fitted!!
  • TomDK
07 Jul 2014 12:22 #119464 by TomDK
Replied by TomDK on topic Re:amada Extreme fitted!!
Dave cc wrote: Looks very interesting just had a glance at there uk agent and website would be nice to get ides of prices compared to king and fox
The UK website is of little use. Their email address is not working.
But i've been in contact with a Spanish reseller of Amada Extreme shocks.
The Explorer II remote reservoir shocks for the Jimny are 736 euro + shipping 45 euro to Denmark for 4 shocks.
The shocks are totally re-valveable and serviceable.
  • Bits4Vits
07 Jul 2014 13:58 - 07 Jul 2014 14:00 #119467 by Bits4Vits
Replied by Bits4Vits on topic Re:amada Extreme fitted!!
Are you sure the OP has an "SJ410"... could be some confusion with worldwide model numbers, as his Avatar picture shows a Jimny...
stuntbike wrote: Oh and one more thing. Is it normal when the car tilts to the driver side when it's lifted? Mine's a RHD so ya it tilts to the right on default.
And it even leans like a Jimny! ;)
Just a thought!
Dave
Last edit: 07 Jul 2014 14:00 by Bits4Vits.
  • stuntbike
08 Jul 2014 23:14 #119542 by stuntbike
Replied by stuntbike on topic Re:amada Extreme fitted!!
Thanks for the info bros! Cuz I just transited from a lowered car to a lifted car. So probably not really used to a 'softer' setting. However the local mechanic recommended 80psi on the front and 40psi at the back. As for spring rate. I'm using a comfort spring.. (not sure of the spring rate) but for the reservoir, the range is from 20-200 psi depending on your liking.
I have used it for about a week now, I must say its been really performing to my expectations. I have tried with different psi on the reservoir. Going from 60/20 to 120/60 and it has made a vast difference.
Tyres pressure set to 30psi on road and 28psi offroad. So far, 8/10 for performance (:
Cheers and live dangerously.
  • darthloachie
09 Jul 2014 08:51 #119551 by darthloachie
Replied by darthloachie on topic Re:amada Extreme fitted!!
most of us jimny guys are too tight to splash out on remote reservoir shocks so you know more than most of us :laugh:
Your tyre pressures sound a bit high - we run 20 psi on the road and 12-15psi off road - the lower the tyre pressure offroad the better the traction - to go really low (9psi) then beadlocks are needed (or maybe innertubes)
  • TomDK
09 Jul 2014 09:08 #119552 by TomDK
stuntbike wrote: Thanks for the info bros! Cuz I just transited from a lowered car to a lifted car. So probably not really used to a 'softer' setting. However the local mechanic recommended 80psi on the front and 40psi at the back. As for spring rate. I'm using a comfort spring.. (not sure of the spring rate) but for the reservoir, the range is from 20-200 psi depending on your liking.
You haven't really answered any of the questions asked. Like, what Suzuki you have. Sounds more like a Jimny than a SJ.
Also, why even ask you local mechanic about reservoir shocks. They don't anything about that. Ask a suspension guy about it, or ask some guy a Amada Extreme. They're very helpful.
  • TomDK
09 Jul 2014 09:13 #119553 by TomDK
darthloachie wrote: most of us jimny guys are too tight to splash out on remote reservoir shocks so you know more than most of us :laugh:
As you can see, having semi-expensive suspension don't mean you know anything about it. Always a good idea to do a bit of research before spending £££.
