Rear prop shaft
  • Global Nomads
30 Jun 2014 21:02 #119080 by Global Nomads
Replied by Global Nomads on topic Rear prop shaft
Similar issue happened- our rear prop shaft 'snapped' and now driving on in 4x4 on the front one.
With a limited budget how much is your average shaft ? (Excuse me)
~ £300
  • C_Jones
30 Aug 2015 10:54 #150977 by C_Jones
Replied by C_Jones on topic Rear prop shaft
lb2e04x wrote: Hi all,
well after driving about listening to a chink a chink from what I thought was the exhaust, turns out to be the rear prop shaft.
Got it up on stands and had a look see. The front end of the shaft appears to go into a cup which is the part making the sound.
Is this part mendable or do I need a new shaft?
thanks
Dave
Shaftesbury
Dorset.
G'day Mate,
I understand that this post is quite old, but I think i may have the same issue. It's not a constant noise, but appears when accelerating hard or when i let out the clutch whilst slowing down (Engine braking).
Did replacing your prop shaft resolve the issue?
Cheers.
30 Aug 2015 11:00 #150979 by kirkynut
Replied by kirkynut on topic Rear prop shaft
I'd forgotten what standard Jimny rear props are like as I've had the Rocklobster on for so long with the SJ front prop on the back.
  • Decklandpt
31 Aug 2015 11:08 #151044 by Decklandpt
Replied by Decklandpt on topic Rear prop shaft
this is gold.
this might just be the solution to the problem i'm having with clunking and grinding noise. had the prop alighned and the ujoint replaced, but didn't cure it. maybe it's those bearing that are shot
Time to create page: 0.171 seconds
