Axel/Hub related issue
  • jimothy
11 Jun 2014 18:11 #117645 by jimothy
Replied by jimothy on topic Axel/Hub related issue
I have just replaced both sides on my jimny. Not only were the bearings worn out but the hub was full of very smelly water. What I can't understand is why know one has made a gaiter to fit the cv joints . And fitted grease nipples to the king pins. It's not that much different in design to the land rover. But I'm sure the last one i had was fitted with grease nipples at the king pin bearings. Plus if you have the added extra of abs don't try and take the sensor out . As the bolts will surely be seized. It best just to I clip the sensor wire and give yourself some slack. I've been there. :(
  • ARichards
11 Jun 2014 18:52 #117647 by ARichards
Replied by ARichards on topic Axel/Hub related issue
Thanks for the great advice guys, I might buy the kit from Ora with the better axel seals. I've got so much rust in the boot ( and by boot I mean, holes going through) by the rear seat belt points, rear beam that holds the body mounts, some more on the chassis near the front. Bought a bit of a shitter really. Going to get some quotes asap. Next mot is in January. Must of had a dodgy mot beforehand as there is no way it would of passed in the condition it is in now.
11 Jun 2014 22:38 #117685 by Rhinoman
Replied by Rhinoman on topic Axel/Hub related issue
jimothy wrote: .Plus if you have the added extra of abs don't try and take the sensor out . As the bolts will surely be seized. It best just to I clip the sensor wire and give yourself some slack. I've been there. :(
Someone got there before me and snapped the bolt off, one of my jobs for tomorrow!
Time to create page: 1.551 seconds
