jimny - mysterious grinding noise
  • mirkom
03 Jun 2014 16:26 #117004 by mirkom
Replied by mirkom on topic jimny - mysterious grinding noise
Brand new car, out of factory. Tried braking in the time of this noise - brakes are ok. No shaking or any other obvious sign of failure, just this noise. Wheel bearings? I don't think so. This noise is much louder. The problem is that this happens only occasionally and it's almost impossible to detect what it is. Can't even say for sure where it comes from. Front wheel I think. Or, maybe, somewhere in between wheels. But it sounds like grinding metal waste in garbage truck.
  • jonesyba420
03 Jun 2014 17:07 #117008 by jonesyba420
Replied by jonesyba420 on topic jimny - mysterious grinding noise
You have 3 options in my opinion:
Option 1: start stripping the whole drivetrain down inspecting everything for wear.
Option 2: drive it untill something breaks then fix it.
Option 3: take it up with the dealer again (best option as its in warranty).
  • mirkom
03 Jun 2014 18:07 #117020 by mirkom
jonesyba420 wrote: You have 3 options in my opinion:
Thanks!
Option 3 seams reasonable. But, my dealer has no idea what this could be. Seams to me they are eirher ignorant or they don't give a damn. Tried to find an answer on my own and by doing so I saw some posts on different forums, but mostly that was about 3-10 years old cars. Some of them seamed to have very similar noise problems, but I could not find a single post with some solution.
  • mirkom
03 Jun 2014 18:13 #117023 by mirkom
Toma wrote: This could be the same as the noise I'm getting. I've traced it down to the drivers side front locking hub. When in 2WD it sometimes try's to engage the locking hub. If I switch to 4WD the noise goes away and I can select 2WD again. It might not make the noise for days and days then do it twice in 10 mins!
Anyway next time it happens open the window and stick you head out then it's easy to tell if it's coming from the front hubs. Also try jacking it up and see if the front hubs lock in.
If you find a cure let me know as I'm not sure where to look next, not sure if it's a hub issue, vac issue or switch problem.
And for how long do you have this noise problem?
What did you do about it? Have you noticed any other isdue or failure?
  • sur5a
07 Jun 2014 12:42 #117296 by sur5a
Replied by sur5a on topic jimny - mysterious grinding noise
i agree with toms,I've had the same issue intermittently on my 2013 jimmy from the passenger side wheel,exactly same symptoms and strategy to stop it.Look near ,under the battery ,there is a small inlet for the vacuum hubs with a bit of foam on it,sometimes mud can block it and upset the vacuum hubs,check your vac lines for kinks ,option ,manual hubs .
I have researched the web about this and seen quite a few people with same problem,hope that helps
  • mirkom
09 Jun 2014 21:53 #117513 by mirkom
sur5a wrote: i agree with toms,I've had the same issue intermittently on my 2013 jimmy from the passenger side wheel,exactly same symptoms and strategy to stop it.Look near ,under the battery ,there is a small inlet for the vacuum hubs with a bit of foam on it,sometimes mud can block it and upset the vacuum hubs,check your vac lines for kinks ,option ,manual hubs .
Thank you! I'll try checking everything I can, but there are things I am not allowed to touch, or I might spoil my warranty. But I will remember your words and remind my dealer to have a look. Since you say you faced the same problems with jimny 2013, I have to ask, was this helpful to you? Have you this grinding noise even now, or it's gone?
Thanks once again. Regards,
Mirko.
