jimny - mysterious grinding noise
  • Spendersjim
09 Jun 2014 22:12 #117517 by Spendersjim
Replied by Spendersjim on topic jimny - mysterious grinding noise
I've had this too. The last time it happened I put it in and out of 4wd half a dozen times with the engine running then reached under the car and tried to spin the forward prop. It would come out of 4wd then you could hear the hubs clunking back in again. After a few tries it seems to have sorted it, but I'm going to remove the hubs and strip and put fresh grease in them.
My car is a 1999 but owned by an older guy from new and I don't think he ever used 4wd.
  • mirkom
10 Jun 2014 07:57 #117531 by mirkom
Replied by mirkom on topic jimny - mysterious grinding noise
Spendersjim wrote: I've had this too. The last time it happened I put it in and out of 4wd half a dozen times with the engine running then reached under the car and tried to spin the forward prop. It would come out of 4wd then you could hear the hubs clunking back in again. After a few tries it seems to have sorted it, but I'm going to remove the hubs and strip and put fresh grease in them.
Thank you. I am not allowed to remove hubs and have a look or I might waste my warranty. But each advice is very appreciated. My dealer didn't even have a proper look first time I visited him. Now I have no intention to drive 400 km and return home "empty-handed". I'll make him check everything that was suggested (if reasonable) to me on this forum.
To be honest, I wasn't even sure where this grinding was coming from. I had some doubts, but just after few suggestions I was sure it's on locking hubs. So, everything is much of a help. Thanks once again!
  • sur5a
10 Jun 2014 13:58 #117553 by sur5a
Replied by sur5a on topic jimny - mysterious grinding noise
yes i still have this problem occasionally,i will get it checked if it doesn't stop also,good luck with yours getting fixed :)
  • mirkom
10 Jun 2014 17:38 #117567 by mirkom
sur5a wrote: yes i still have this problem occasionally,i will get it checked if it doesn't stop also,good luck with yours getting fixed :)
Thanks! I have an appointment with dealer next week. No big expectations, but I'll keep you informed. If I solve my problems, I'll let you know.
  • sur5a
24 Jun 2014 00:40 #118449 by sur5a
Did you find the problem Mirkom
  • mirkom
26 Jun 2014 11:47 #118677 by mirkom
Not sure, yet. I took my car from the dealer today. He said there was nothing wrong with vacuum. He has inspected it and cleaned it properly. Everything works just fine, he said. All I can do is to wait and see, but no big expectations.
Time to create page: 0.199 seconds
