Kingpins need doing, just the bearings needed or kingpins too??
22 May 2014 22:45 #116072 by minibbb
markyp2000 wrote: Pembury at the mo but in the proces of moving cant do any thing for a few weeks
That's cool mark no worries mate. I'm sure my mate can cope, I emailed him martins guide and he seems happy he can manage it, I'll tell him it should be roughly three hours all in. I gather contrary to guide its not necessary to totally split the hub?
  • Yellostreak
23 May 2014 03:04 #116079 by Yellostreak
you can take the whole hub and half shaft assembly out as 1, change the bearings and inner seal and then put back as 1 unit... its awkward and there is a risk of damaging or popping out the new seal but it can be done. doing this I get it down to about 15-20 minutes per side..
biggest tip I can give is lift the side you are doing higher than the other side so all the diff oil stays in the axle and not on the floor!
And I work in IT not a garage!
  • markyp2000
23 May 2014 07:09 #116088 by markyp2000
Yer 15 20 mins is a good time but id rather take it all apart clean every thing also i clean the thrads on all the bolts and holes soi no thay will come out next time all i can say it you dont need to undo the 4 17mm bolts behind the hub
  • idiotmobil
23 May 2014 07:49 #116091 by idiotmobil
ill do both side for £75 for you including cleaning the cvs right out im only in Southampton
  • Yellostreak
23 May 2014 08:23 #116096 by Yellostreak
markyp2000 wrote: Yer 15 20 mins is a good time but id rather take it all apart clean every thing also i clean the thrads on all the bolts and holes soi no thay will come out next time all i can say it you dont need to undo the 4 17mm bolts behind the hub
I do all this.. I even clean the threads.. ;)
  • idiotmobil
23 May 2014 08:56 #116098 by idiotmobil
last time I done mine I went the whole hog and even painted the lot lol
Time to create page: 0.390 seconds
