Confused by older style 4wd gears
  • Whippersnapper 86
02 Apr 2014 19:17 - 02 Apr 2014 19:18 #111067 by Whippersnapper 86
Confused by older style 4wd gears was created by Whippersnapper 86
Ok so I'm hoping I haven't made an error but I've just been and bought a jimny it's a 2001 model and has the 4wd gear stick. Tbh I don't know much about this other than I heard you shouldn't use them whilst driving on normal roads. Anyway It went straight down into 4wd mode but I don't know what else I should be looking for as it didn't bleep or light up anywhere on the dash but happily stayed in the downwards 4wd position
Does this sound right?
Last edit: 02 Apr 2014 19:18 by Whippersnapper 86.
02 Apr 2014 19:23 - 02 Apr 2014 19:24 #111068 by Busta
Instructions for the different drive options and when to use them can be found on the drivers sun visor.
There are 3 positions (as indicated on the top of the gearstick)
1: 2wd high range (lever fully forward)
push lever backwards to
2: 4wd high range
push lever down and backwards to
3: 4wd low range
In the 2nd and 3rd positions a '4wd' light should illuminate on the dashboard. If there is no light, or the light flashes, there is a fault in the system and 4wd will not engage.
Last edit: 02 Apr 2014 19:24 by Busta.
  • Whippersnapper 86
02 Apr 2014 19:34 #111069 by Whippersnapper 86
Replied by Whippersnapper 86 on topic Confused by older style 4wd gears
Busta wrote: Instructions for the different drive options and when to use them can be found on the drivers sun visor.
2: 4wd high range
3: 4wd low range
Hmm I genuinely did not notice a light Is it obvious or do you have to look for it? If it is broken is it much to fix? Got a feeling it won't, be just my luck :/
  • deedar
02 Apr 2014 19:49 #111070 by deedar
Replied by deedar on topic Confused by older style 4wd gears
Iff it is not working it qill more than likey be stupid vacum if it is I would rip it all off and buy a setvof manual locking hubs
  • Whippersnapper 86
02 Apr 2014 20:17 #111073 by Whippersnapper 86
deedar wrote: Iff it is not working it qill more than likey be stupid vacum if it is I would rip it all off and buy a setvof manual locking hubs
Will the car workplace without this working? I drove it and it felt lovely. How much will this cost to get sorted as it's the reason I bought a jimny to get me about in the bad winter weather. I only had a quick drive of it so maybe the 4wd does work I was just scared of potentially breaking it so tried it a couple of times whilst stood still
02 Apr 2014 20:21 - 02 Apr 2014 20:23 #111074 by Busta
Yes the light will be obvious.
You will need to do a bit of investigation. This guide will help you: www.bigjimny.com/images/documents/Check_the_vacuum_system.pdf
Page 6 has a troubleshooting table which will help you work out what parts of the system are at fault.
Don't be scared of the vacuum system. A lot of people dislike it but in truth it's relatively simple, effective and convenient.
Last edit: 02 Apr 2014 20:23 by Busta.
Time to create page: 0.171 seconds
