egr blank off enging runing better
  • 410shotgun
01 Apr 2014 19:04 - 01 Apr 2014 19:06 #110893 by 410shotgun
egr blank off enging runing better was created by 410shotgun
blanked the egr off today and the engine is running a lot better
and eml not on
what I did is took the exhaust manifold off
found a m6 dome head bolt ground the head down so it was a tight fit in the little tube
on the manifold approx. 12mm hole taped it in and refitted the manifold
been for a 10 mile drive no light on and runs a lot better and ticks over better
this is the twin cam engine
you could put a small core plug in it if you had 1
Last edit: 01 Apr 2014 19:06 by 410shotgun.
  • jonesyba420
01 Apr 2014 20:31 #110905 by jonesyba420
Replied by jonesyba420 on topic egr blank off enging runing better
What running issues were you having?
  • 410shotgun
01 Apr 2014 20:53 #110914 by 410shotgun
Replied by 410shotgun on topic egr blank off enging runing better
the tick over was very lumpy sometimes
and when I pulled up at a give way the revs went right down but did not cut out
but not all the time
also a misfire when the revs were low
  • idiotmobil
01 Apr 2014 20:55 #110916 by idiotmobil
Replied by idiotmobil on topic egr blank off enging runing better
mine does the rev drop thing havnt toke much notice tho
  • jonesyba420
01 Apr 2014 21:04 #110920 by jonesyba420
410shotgun wrote: the tick over was very lumpy sometimes
Mmmmmmm mine does that, do you have any pics of what you done?sounds simple enough just not sure what tube your on about.
01 Apr 2014 21:19 #110924 by Rhinoman
Did you make sure it was working properly first? the engine will run better with a working EGR and it is not active at idle so it shouldn't affect tickover unless its sticking. Have you driven it far? you will usually throw a code when you decelerate for an extended period of time because that's when EGR is tested.
Time to create page: 0.297 seconds
