STEEL RIMS VS ALLOY RIMS
18 Mar 2014 17:53 #108987
Replied by helijohn on topic STEEL RIMS VS ALLOY RIMS
I run both. The wider alloys rims just about weigh the same as the narrower steels. Much of the weight is in the tyre so you got to get what you feel like you want. If I were rock climbing I'd stick with steel if only that I can buy a single replacement for peanuts. Steel needs less care and maintenance to a certain extent. On road only and it makes little difference steel or alloy apart from looks but if you want to go wider then go alloy for road use. Main thing is to get as big a tyre height as you can.
- rogerzilla
18 Mar 2014 21:06 #109039
by rogerzilla
Replied by rogerzilla on topic STEEL RIMS VS ALLOY RIMS
The other thing about steelies is that they shrug off scrapes with only paint damage, whereas alloy is deeply gouged.
