STEEL RIMS VS ALLOY RIMS
  • Millzy
18 Mar 2014 02:22 #108933 by Millzy
STEEL RIMS VS ALLOY RIMS was created by Millzy
hi all ive got size 15 steel rims and obviously these would be quite heavy compared to alloys I was just wondering what people have experienced and biggest size tyres can put on alloys at the moment ive got 275x75x15 M/Ts on !!!
Any help be great thank you ??
  • Jimny_Aus
18 Mar 2014 05:10 #108936 by Jimny_Aus
Replied by Jimny_Aus on topic STEEL RIMS VS ALLOY RIMS
what are you trying to achieve?? just biggest tires possible?? :silly:
  • rogerzilla
18 Mar 2014 06:33 #108937 by rogerzilla
Replied by rogerzilla on topic STEEL RIMS VS ALLOY RIMS
Only very good alloys are lighter than steelies. Most of them are actually heavier, sometimes considerably so. Aluminium is about 1/3 the weight of stee; but is much weaker so there is an awful lot of it in a cast wheel; a steel wheel is just two thin pressings, welded together.
  • ZookFastback
18 Mar 2014 09:43 #108943 by ZookFastback
Replied by ZookFastback on topic STEEL RIMS VS ALLOY RIMS
I concur with rogerzilla. I have factory Jimny mags and they are each over a kilo heavier than my steel Sunraysia wheels. They are some of the heaviest wheels I have ever used but I do think they contribute to the good ride on the road of my Jimny. The Sunraysia's are very strong but light and perfect for the off-road tyres I have on them plus they can take a good knock and I can easily hammer a dent out of them.
Jimny Alloys
Sunraysia Steels (before off-roads fitted)
18 Mar 2014 12:50 #108951 by Rhinoman
Replied by Rhinoman on topic STEEL RIMS VS ALLOY RIMS
I had some Mangel alloys from a wideboy Vit and they were 50% heavier than the steels that I replaced them with. I'm not a fan of wide tyres on a Suzuki, narrower tyres seem to give better handling and steering.
Have you really got a 275 fitted or should that read 215?
18 Mar 2014 17:50 #108985 by funkyjimny
Replied by funkyjimny on topic STEEL RIMS VS ALLOY RIMS
If using off road stick to steel wheels, if they get hit by rocks they bend and can be bent back, whereas an alloy wheel tends to crack leaving it scrap.
Gary
Time to create page: 0.713 seconds
