Rough Country N2.0 (ORA +4") Shock length
- TomDK
16 Mar 2014 12:16 #108749
by TomDK
Rough Country N2.0 (ORA +4") Shock length was created by TomDK
Can anyone help me out. I'm not at home and wont be for the next month, so need a little help
Can anyone tell me the compressed length of a N2.0 front shock from the +4" ORA suspension kit. Measured from mid-eye to bottom of top stem?
Thanks
Thanks
16 Mar 2014 18:44 #108775
Replied by mlines on topic Rough Country N2.0 (ORA +4") Shock length
- TomDK
16 Mar 2014 19:17 #108783
by TomDK
Replied by TomDK on topic Rough Country N2.0 (ORA +4") Shock length
Thanks Martin.
Hope I'm not sounding too ungrateful. Are you sure the measured shocks are from the 4" lift and not the 2.5" lift?
I'm only asking, because something in my head tells me that the +4" shocks measure around 61 cm extended. Measured it a while ago , but I could be wrong :blush:
16 Mar 2014 22:00 #108795
No problem, I have unboxed one to have a look.....(I sell the same ones)
I guess the manufacture lists a slightly conservative figure as you would not want to hit the end stop in real life.
- TomDK
17 Mar 2014 02:34 - 17 Mar 2014 02:35 #108813
by TomDK
Thanks Martin.
I'm asking because I'm trying to figure out what Bilstein shock that fits. Here in Denmark, we're not allowed to modify the suspension mounts on the chassis. So shocks will have to around same length as either standard to match those of a suspension lift.
For now, I'm consider either Bilstein 5125, 5165 or 7100 series. Just need to figure out correct valving
www.eshocks.com/bil_ORsb.asp?Series_Inde...1&Manf=All&SubChar=Q
www.polyperformance.com/shop/Bilstein-51...s-Shock-p-26817.html
BTW, Some of the 5125 shocks have stem upper mounts, and would be an ideal shock for most Jimny's with a 2-4" lift. And provide much better control offroad than many other cheap shocks offered with a lift kit. And they're not that expensive.
Bilstein 5165
Bilstein 5125
Bilstein 5165
Bilstein 5125
Last edit: 17 Mar 2014 02:35 by TomDK.
- Jimny_Aus
17 Mar 2014 05:04 #108814
by Jimny_Aus
Replied by Jimny_Aus on topic Rough Country N2.0 (ORA +4") Shock length
Bilstein 5165 look tidy mininum of 6.3" travel :woohoo:
what up with the valving though, never heard of it ??
Time to create page: 3.569 seconds
