m13a PAS belt?
  • jonesyba420
13 Mar 2014 21:16 #108497 by jonesyba420
Replied by jonesyba420 on topic m13a PAS belt?
Ill get the misses to get me a 854 and see if that fits.
15 Mar 2014 16:52 #108645 by Basketcase
Replied by Basketcase on topic m13a PAS belt?
I've literally just managed to work out how to get the belt on! Put belt on bottom pulley under tensioner onto too p/a pulley as far round as you can then wedge a flat screwdriver between belt and p/a pump pulley crank engine it slips straight on
15 Mar 2014 16:59 #108647 by kirkynut
Replied by kirkynut on topic m13a PAS belt?
I was just reading through the thread and was going to suggest getting it on as much as you can, then crank the engine a quick turn of the key and it usually goes on the rest of the way, if not another quick turn of the starter motor.
Don't have any screwdrivers or anything wedged into it to fly out and cause damage or injury though.
15 Mar 2014 17:05 #108648 by facade
Replied by facade on topic m13a PAS belt?
One of my pulleys has a great kink in it from where I tried the "put a screwdriver under the belt and turn the engine" idea :ohmy:
  • Beano
15 Mar 2014 20:42 #108683 by Beano
Replied by Beano on topic m13a PAS belt?
+1
Just did this myself the other day. Put the belt on as far over the top of the pulley as you can with fingers, then a quick crank of the key and off again should sort it out..
Tried and tested!
Time to create page: 0.292 seconds
