front metal structure rotten?
- jimnylee
05 Mar 2014 19:44 - 05 Mar 2014 19:45 #107314
by jimnylee
front metal structure rotten? was created by jimnylee
Hi folks ,I'm wondering if anyone could help me? this is my first posting on the forum. I have just recently bought my first jimny a 2001 with just under 72k ,it seems like a nice clean example and has at some point had waxoyl applied underneath, today I was having a look under the bonnet and noticed that the metal frame in front of the radiator,if you follow the two spars down there is a cross channel were the top of the bumper anchors onto, I found the channel is basically split and heavily rotted it also contains part of the front light wiring loom,I'm wondering if this would be a structural fail for the mot? and is this cross section available to buy? as it all seems spot welded into place?? Any help appreciated cheers lee
Last edit: 05 Mar 2014 19:45 by jimnylee.
- rogerzilla
05 Mar 2014 20:48 #107341
by rogerzilla
Replied by rogerzilla on topic front metal structure rotten?
Is it part of the chassis or the body? If the latter, it could be a fail assuming the tester spots it and considers it unsafe. If it's part of the bodywork then it's unlikely to fail as you can get away with an amazing amount of corrosion when there is a separate chassis.
It is almost certainly a weld-in job. As you've found, early chassis weren't galvanised.
- idiotmobil
05 Mar 2014 22:05 #107360
by idiotmobil
Replied by idiotmobil on topic front metal structure rotten?
Im sure any rust body or chassis within 12inch of a mount etc is a fail. Some moters will let things slide but by law they shouldn't but glad they do. there not stupid I had a bit near my rear body mount but woild do nothing to be unsafe in any way
- Dave cc
05 Mar 2014 22:10 #107362
by Dave cc
Replied by Dave cc on topic front metal structure rotten?
Put a picture up it always helps to see the problem
- Jutwit
05 Mar 2014 22:53 #107381
by Jutwit
Have later models got galvanised chassis then? If so when from?
Replied by Jutwit on topic front metal structure rotten?
rogerzilla wrote: Is it part of the chassis or the body? If the latter, it could be a fail assuming the tester spots it and considers it unsafe. If it's part of the bodywork then it's unlikely to fail as you can get away with an amazing amount of corrosion when there is a separate chassis.
05 Mar 2014 23:38 #107395
by kirkynut
Replied by kirkynut on topic front metal structure rotten?
Later models have galvanized bodies, not chassis. Zuki chassis don't seem to rust for some reason.
I think it was either 05 or 06 on that were galvanized but someone will know for sure.
OP, as Dave says, we need a piccie!
Time to create page: 1.380 seconds
