MTs on stock wheels - transfer case options?
- jtayl153
27 Feb 2014 07:50 #106311
by jtayl153
MTs on stock wheels - transfer case options? was created by jtayl153
Ok so I have a 2008 Suzuki Jimny VVT, manual, push button transmission.
All the mechanics are stock.
I'm putting some mud tyres on the stock wheels (alloy 15" x 5.5").
Do I need to upgrade the transfer case? Is it absolutely essential?
What will happen if I choose not to?
Can anyone recommend and All-on-one kit that I'd be able to install?
I've got access to the tools I'd need and I have a stock t-case thats only done 20000Kms. Is there a modification that someone can recommend that means I dont need to buy another t-case.
Cheers
Cheers
- jonesyba420
27 Feb 2014 07:55 #106312
by jonesyba420
Replied by jonesyba420 on topic MTs on stock wheels - transfer case options?
Depends what size tyres you want to fit buddy.
- jtayl153
27 Feb 2014 08:01 - 27 Feb 2014 08:07 #106313
by jtayl153
Replied by jtayl153 on topic MTs on stock wheels - transfer case options?
Most likely it'll be a set of Maxxis Bighorn MTs.
235/75R15
235/75R15
Last edit: 27 Feb 2014 08:07 by jtayl153.
- Mister Stu
27 Feb 2014 08:09 #106315
by Mister Stu
Replied by Mister Stu on topic MTs on stock wheels - transfer case options?
You'll be looking at 2" with a fair bit of trimming or 3-4" with minimal trimming for that size as thats what iv got
- jtayl153
27 Feb 2014 08:28 - 27 Feb 2014 08:31 #106318
by jtayl153
Whats the best and neatest way to trim it?
and with the 2" lift, are there any other changes I'll need to make?
camber correction? etc?
Last edit: 27 Feb 2014 08:31 by jtayl153.
- jonesyba420
27 Feb 2014 08:59 #106321
by jonesyba420
plenty of threads on the trimming situation mate have a search, i find it better to use google rather than the search on here as its generally better and usually returns results from here anyway.
extended brake lines (especially if you remove the ARB for maximum flex), some people fit caster correction bushes some dont, not sure if adjustable panhards are needed on a 2"lift someone will clarify what else is needed.
