rear shock absorber removal and refit
04 Feb 2014 13:39 #103328 by robs5230
hi, my new rear shocks are here today. any tips for removal of the old ones ? it has a 3" lift. i did order new top bolts from martin and the lower bolts are good ( mount drilled out and new bolts ).
i'm guessing the top bolts have a captive thread to screw into as i didnt get nuts with the new bolts. are the old bolts likely to break ? cheers rob
standard jimny - for now
04 Feb 2014 13:46 #103329 by mlines
Yes, top bolts have captive nuts.
Soak, Soak and Soak again in penetrating oil. I let them soak over a number of days, refreshing the oil every few hours!
04 Feb 2014 13:53 #103330 by robs5230
cheers martin .oh bum. not what i wanted to hear but i thought it may be the case. do they ever snap off in the captive thread ? and if they do how is it rectified ?
thanks
04 Feb 2014 13:57 #103331 by mlines
I am not sure, I have not broken any.
Also note that the bushes in the shocks will need trimming to fit. This is normal for most aftermarket shock absorbers that come with standard size bushes, a small hacksaw will sort.
04 Feb 2014 14:01 #103332 by robs5230
cheers, just been out and under it with the penetrating oil. the bolts head is facing forward and there seems very little room for hands/tools. presumably thats right ?
04 Feb 2014 14:04 #103333 by mlines
Yes, long and thin tools
Time to create page: 2.764 seconds
