2 Post Ramp and Front Swivel
10 Jan 2014 22:16 #100057 by robs5230
idiotmobil wrote: Your right main reason king pins can be other things could just be a bad inner axle seal but these mainly go due to other reasons check for movment in the wheel hold 12 and 6 if wibble kingpins hold 9and 3 if wobble wheel bearing these are not exact as I had not wobble no leaking but changed my kingpins for peice of mind and found one fell in bits as I toke it out I think thrre a easy job some would not agree I think it depends on skill and if you get unlucky with stubborn bolt etc hope this helps
Ive just noticed you have said grease this could mean seal as tgats whats in the swivel but if its more runny like oil more likely as above
i'll have to defer to your better judgement here mate. no actual experience of either . just something i read. rob
standard jimny - for now
10 Jan 2014 22:30 #100063 by auchenblae
kirkynut wrote: On the two post part of the subject, it can be tricky on older ones with shorter arms but can you not get the pads to sit on the chassis just inside the radius arm mounts.
I realise this makes them even closer together but at least they are on a flat surface.
I have not put mine on a two poster but I know it has been on one recently as last year I had the rear wheel bearings done at my step father in law's garage and it went on his then.
Just taking advice from the Suzuki workshop manual that tells you to put the lift pads on the chassis brackets that hold the trailing arms to the chassis.
No problem length wise are the arms are around 1,200mm it has symmetrical arms and the longest length is at the front where they go out about 900mm. Some of the 2 post ramps with short front arms could not get into the lifting points.
eddie
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
  • GuardianAngel
10 Jan 2014 22:56 #100072 by GuardianAngel
Replied by GuardianAngel on topic 2 Post Ramp and Front Swivel
King pins are pretty easy, it's just the stinky rotting grease and water that can make it unpleasant :O
  • idiotmobil
10 Jan 2014 23:02 #100073 by idiotmobil
Replied by idiotmobil on topic 2 Post Ramp and Front Swivel
one thing to know is check the top one and keep it as a spare as they seam to do the bottom one in long before the top ive just replaced a cv and done the king pins at same time and the bottom one had had it but top seems ok so ill be keeping that one, same happened when I done the other side months ago witch has to come apart now to do cv and ill check the king pins and have a ok spare to replace the bottom one if its crap
10 Jan 2014 23:15 #100078 by auchenblae
Both Kingpins were done at 3 years old so must be that time again as the cars is 7 years old. Will check them tommorow.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
11 Jan 2014 10:59 #100091 by auchenblae
Just checked and no play on either wheel holding top and bottom of both tyres or doing it side to side so the King Pins appear to be OK at the moment.
eddie
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.137 seconds
