Hi Level braking light - 07 hardtop
15 Dec 2013 18:25 #96188 by Mike G
Hi Folks,
My 07 hardtop Jimny brake lights work fine apart from the hi level one. I'm guessing that both the rear brake lights and hi level brake light are run off the same fuse? Am I correct in saying this, I believe the hi level light is factory fitted (i've never bought brand new, so can't confirm this)?
I checked the bulb itself for continuity with a fluke, it's fine, so I then checked the bulb socket, but there's no voltage there when the brake pedal is depressed. Next thought is that the wiring may be broken or shorted.
I had an issue on my last Jimny where the rear lights didn't work, turned out to be a shorted damaged wire which ran on top of the passanger footwell, underneath the carpet. I don't really fancy tearing out all the insides of my motor this time of year, especially as I don't have a garage to carry this out, so wondered if anyone knew the route this cable takes, or if I've missed something out.
Any info is appreciated.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
  • markyp2000
15 Dec 2013 18:42 #96191 by markyp2000
Replied by markyp2000 on topic Hi Level braking light - 07 hardtop
Are thay switch earth or switched live take a look at the wiring between the body and rear door
15 Dec 2013 19:05 - 15 Dec 2013 19:06 #96200 by Mike G
Hi Marky, thanks for the info.
I'm not an electrician, so not sure what switched earth and switched live are.
Is 'switched earth' where the circuit is completed by earthing to the body and 'switched live' would be earthed back to the battery terminal?
Last edit: 15 Dec 2013 19:06 by Mike G. Reason: incorrect greeting
  • markyp2000
15 Dec 2013 19:56 #96220 by markyp2000
Switched earth is you have a live feed there then when its switch it puts an earth to it
Or
Switched live is it has an earth fead there and then when its switch it put a live feed to it
15 Dec 2013 20:02 #96227 by Mike G
ah, ok.
So it's like a positive or negative earth set up.
Either way, when the brake pedal is depressed, I should be able to measure a DC voltage going to the bulb, but I'm not. So I guess I just need to take some paneling down and find the route of the wire.
  • markyp2000
15 Dec 2013 20:24 - 15 Dec 2013 20:25 #96243 by markyp2000
Just go to the rubber bit between the door and the body and see if the wire is broken
Last edit: 15 Dec 2013 20:25 by markyp2000.
Time to create page: 0.582 seconds
