Radio died
  • Lapala
22 Dec 2013 05:53 - 22 Dec 2013 06:07 #97136 by Lapala
Replied by Lapala on topic Radio died
2008 Jimny.
Just out of the blue, one morning the radio did not work.
Checked all the fuses.
The lighter also is not working.
When I switch on the lights, the radio is illuminated.
I pushed in a disk. It did not feed in.
Then I started the car and the cd was ejected.
So some kind of supply is still on the radio.
Maybe it is a earth leak?
I still have to investigate.
Last edit: 22 Dec 2013 06:07 by Lapala.
  • Northern-Wanderer
22 Dec 2013 14:15 #97167 by Northern-Wanderer
Replied by Northern-Wanderer on topic Radio died
Dougall wrote: Mine is a bit temperamental (it's the newer style clarion unit) and sometimes refuses to switch on. It's a simple case of switching the engine off and on again, sometimes a couple of times before it works. Haven't found any problems with the wiring loom but for now the engine off/on trick appears to work.
+1 :(
  • little jimny
22 Dec 2013 14:44 #97168 by little jimny
Replied by little jimny on topic Radio died
Lapala wrote: 2008 Jimny.
I think the feed for the stereo and the lighter are on the same fuse, so I'd try swapping the fuse out for a new one - worth trying as sometimes even if the fuse looks OK a new one gets you up and running again.
Time to create page: 0.126 seconds
