Wiring spot lights up - Not done this before?!!
- Boomer
01 Dec 2013 17:46 #94171
by Boomer
Replied by Boomer on topic Wiring spot lights up - Not done this before?!!
Cheers> I will fit them when they arrive and run a bit of 17amp twin with single relay as a test with wiring routed as you described earlier.
- winter
12 Dec 2013 23:29 #95691
by winter
Replied by winter on topic Wiring spot lights up - Not done this before?!!
so if i wanted to run two led spots on a switch only do i need a relay or not as my mate said you dont need a relay ? anyone can clear this up be good
- funny16
24 Dec 2013 18:50 #97438
by funny16
Replied by funny16 on topic Wiring spot lights up - Not done this before?!!
Hai Winter:
I don't think you need a relay:
because P = U X I
you leds ( 2 x 18 watt = 36 watt ?? ) = P
12 volt your voltage car = U
So your current consumption = 3 amp = I
For 3 amp, you don't need a relay.
Ofcorse you can also use one if you want......
because P = U X I
- k08888
26 Dec 2013 11:00 #97543
by k08888
Replied by k08888 on topic Wiring spot lights up - Not done this before?!!
I would use always relay when connecting extra light or something like that; when you make it with relays, you can be bretty sure that your switch wount melt or you dont burn your car cause of bad quality switches.. And its not that difficult to set up.
I dont want to open new topic, so i borrow this one little bit: :laugh:
Has anyone using 120w led bars (combo) in their cars as a extra driving lights? How they are working; is there enough light?
I`m thinking of butting one 120w led bar to my front bumber and use it with original high lihgts..
Time to create page: 0.156 seconds
