Wiring spot lights up - Not done this before?!!
- piprice
29 Nov 2013 10:26 #93750
by piprice
Wiring spot lights up - Not done this before?!! was created by piprice
I know its all over the forum if using the search button but i have no idea about wiring and the jargon thats used lol
So im part of a limited number of people with a soft top and a roof bar :woohoo:
Now with the soft top, whats the best way to run the wiring?
hard tops you can run down the radio aerial route, but i have a folding canvas that will get in the way :dry:
Was thinking of drilling a hole and using a grommet and some friendly sealant and then worrying about the wiring inside at another time....
Also what wiring kit will i need, as far as im aware, 2 spot lights are wipacs (12V 55W H3 bulb) and the other 2 are apprantley the same as the wipac spec (12V 55W H3 bulb)
My roof rack is plastic coated then metal underneath this, how do i earth each light to the roof rack if this is needed?
My brother in law says i dont need a relay? but i want to do this properly.... and would like them on a switch..... a 4 way switch would be nice..... 1 setting for the outter lights, 1 setting for all 4 to be on, and one for the middle two, and then off..... is this possible?
Then on to the rear working light - ive heard people running this in with the reverse switch? but wouldnt this mean when i select reverse the mini spotlight will come on?
Sorry for the dumb ass questions, but wiring is not something i enjoy lol....
what effect will the spotlights have on my battery etc?
will get some photos of my light setup....
- jonesyba420
29 Nov 2013 11:12 #93755
by jonesyba420
Replied by jonesyba420 on topic Wiring spot lights up - Not done this before?!!
i think but not 100% sure, the relay is needed if you want them to come on with main beam
wiring to the reverse switch for you rear spot will indeed make it come on when engaging reverse, if its a work light so to speak just wire it to a live source and fit a switch for it then its on when you want.
- piprice
29 Nov 2013 11:18 #93759
by piprice
Replied by piprice on topic Wiring spot lights up - Not done this before?!!
Another photo.
This is where I get lost!
Wheres a live etc at the rear, I'm sure someone will come along with the words 'multimeter'
Just want simple lol
Not fussed about high beam and all that as It will be on a switch for when I need them, don't want to blind people...
But really what ever is easiest, if it's easier to wire them (somehow) to high beam then it will have to be.....
- Boomer
29 Nov 2013 11:27 #93760
by Boomer
Replied by Boomer on topic Wiring spot lights up - Not done this before?!!
+1 to this, although I will be doing it to a hardtop soonish. Looking to wire them via a switch so I can either have them work with the high beam or just flip the spots on .. I get lost with wiring and what I need to do (pass me a hammer, adjustable spanner and duct tape and I am fine)
The plan is to fit 3 x www.amazon.co.uk/gp/product/B00D769WUS/r...00_i00?ie=UTF8&psc=1
So please enlighten us with your wisdom folks ... wiring diagrams in crayon are perfectly acceptable ..
- piprice
29 Nov 2013 11:34 - 29 Nov 2013 11:40 #93762
by piprice
Last edit: 29 Nov 2013 11:40 by piprice.
- tommyguns
29 Nov 2013 11:50 #93764
by tommyguns
Replied by tommyguns on topic Wiring spot lights up - Not done this before?!!
need to wire up my spots on my ragtop too. when i had them in my freelander i had them all going to a chocolate block in the glove box, had 4 spots on one swtich, work light on the other, and then dixies on another
might look into wiring the spots into mainbeam though
Time to create page: 0.281 seconds
