2" lift but i want more...help!
  • winter
21 Nov 2013 20:14 #92506 by winter
Replied by winter on topic 2" lift but i want more...help!
why not go for 16" rims will give you 1/2"more under you diff if you keep same size rubber but on 16s :)
Paqueras wrote: With OEM rims? 15x5.5J
  • reaper
21 Nov 2013 20:23 #92511 by reaper
Replied by reaper on topic 2" lift but i want more...help!
Some front and rear shock spacers along with the spring spacers will give you an extra 1.5" but then you will probably find you need some castor correction arms . . . .not just bushes
21 Nov 2013 21:08 #92534 by mlines
I would go body lift
Sent from my HP Slate 7 using Tapatalk 4
  • Paqueras
21 Nov 2013 23:59 #92556 by Paqueras
Replied by Paqueras on topic 2" lift but i want more...help!
reaper wrote: Some front and rear shock spacers along with the spring spacers will give you an extra 1.5" but then you will probably find you need some castor correction arms . . . .not just bushes
I was thinking about that....
Im buying a Apio front bumper (chinese replica) for more clearance. I will analyze the situation after that.
Thanks!
  • Paqueras
26 Nov 2013 02:20 - 26 Nov 2013 02:22 #93258 by Paqueras
If i go body lift 2" more inches i will need castor correction arms?
Or the body lift is a totally different thing and i dont need to change the suspension setup?
Last edit: 26 Nov 2013 02:22 by Paqueras.
  • jonesyba420
26 Nov 2013 07:35 #93265 by jonesyba420
Replied by jonesyba420 on topic 2" lift but i want more...help!
Body lift is unrelated to suspension geometry your merely raising the body off the chassis.
Time to create page: 0.159 seconds
