4wd low not working
  • helijohn
08 Nov 2013 17:32 #89967 by helijohn
Replied by helijohn on topic 4wd low not working
gilburton wrote: Mine won't go in unless you floor the clutch!
That isn't axle wind up I am hearing is it?
  • gilburton
08 Nov 2013 17:40 #89969 by gilburton
Replied by gilburton on topic 4wd low not working
That's at a standstill for 4L ;)
  • helijohn
08 Nov 2013 17:42 #89970 by helijohn
gilburton wrote: That's at a standstill for 4L ;)
Ah, it sounded like you had locked up the trans.
  • gilburton
08 Nov 2013 18:16 #89975 by gilburton
As I don't offroad I've never used 4L but I have the same symptoms eg flashing light,beeps if I don't press the clutch fully to the floor. Just thought it might be a solution?? Apart from that 4H goes in lovely on the button when required in the winter :)
  • Leathery1
08 Nov 2013 22:30 #90039 by Leathery1
Replied by Leathery1 on topic 4wd low not working
Got one of the oldest Jims in the country and it goes from 2 to 4 to 4L any time any place anywhere so long as all wheels are in a straight line and you aren't going too fast for 4L. Mind you its good old fashioned levers, not this pressy bottony stuff which I dont trust one bit!
Mind you, always gives a little crunch on selecting 4L, stationary, moving, whatever. Just lets you know its in there!
  • Hastiekid
09 Nov 2013 08:39 #90077 by Hastiekid
Replied by Hastiekid on topic 4wd low not working
If its a 07 plate it obviously is an elecy transfer box. I have just rebuilt one and they realy aren't that complicated. the only connections on the box are a motor plug and two proximity switches, there may be an ECU plug I cant remember. The motor drives and knows where it is from the switches controlled through the ECU. If one of the switches is faulty of more lightly it just has a poor connection it will not register and so in effect no 4WDL. In essence pull off all connections on the T=Box, inspect and clean them before going any further.
Hope this helps
Ian
Time to create page: 0.200 seconds
