Free-flow exhaust pipe/muffler on a Jimny? Useful?
- vegetablejoe
06 Nov 2013 08:41 #89582
by vegetablejoe
Replied by vegetablejoe on topic Free-flow exhaust pipe/muffler on a Jimny? Useful?
Thank you all for your inputs!
Will see how low a cherry bomb muffler will sit. May not be practical during the rainy season on our flooded streets....
Looks like the only benefit to me would be to piss off my cranky neighbor with a noisy muffler. That by itself would make the change-over so worth it, hehe...
Jaime
Jaime
06 Nov 2013 09:49 #89584
I'd love to fit one, but a quiet one, if it were practical preferably a side one!
Replied by helijohn on topic Free-flow exhaust pipe/muffler on a Jimny? Useful?
vegetablejoe wrote: Will see how low a cherry bomb muffler will sit. Jaime
- Yellostreak
06 Nov 2013 14:53 #89611
by Yellostreak
Replied by Yellostreak on topic Free-flow exhaust pipe/muffler on a Jimny? Useful?
i'm planning on a cherry bomb rear muffler but only so I can get is coming out straight at the back probably at chassis rail height so it is well out the way of any departure angle nasties.. as soon as the rest of the exhaust is dead it will be replaced by a stainless system from the downpipe back.. none of this is for performance but you never know
06 Nov 2013 21:02 #89692
by Rhinoman
Replied by Rhinoman on topic Free-flow exhaust pipe/muffler on a Jimny? Useful?
The ECU is mappable but it wouldn't be needed for an exhaust change, the feedback from the lambda sensor would be enough to correct the fuelling. Don't change to the 1.6 injectors on a stock engine it won't run right at all.
The following user(s) said Thank You: Yellostreak
- steffan
06 Nov 2013 21:18 #89698
by steffan
Replied by steffan on topic Free-flow exhaust pipe/muffler on a Jimny? Useful?
So when my 1.6 is fit after Christmas should I have it mapped to compensate also planning to decat the beast the environment can suck a fat one I want optimum performance lol
07 Nov 2013 13:02 #89774
by Rhinoman
Which ECU do you have if its the one with the metal case then I've already done a lot of work on that ECU. I'm intending to change my 1.6 ECU for a remapped 1.3 ECU so I can fine tune it - the Jimny ECU can be remapped, the coil pack Baleno one can't but can be read.
The 1.3 has a very different torque curve, with a 1.6 engine you are relying on the fuel trims to compensate fuelling, any rapid changes in RPM or load mean that the fuelling will be out. The other issue is the timing for which the ECU cannot make any corrections.
