rev counter signal
  • supergaz
18 Oct 2013 20:32 #86935 by supergaz
Replied by supergaz on topic rev counter signal
Rhinoman wrote:
j999pre wrote: I used a code reader that gaz has in his car but found no codes stored? I'm gonna try some different clocks to check.
You want one that outputs live data so you can compare the RPM reading to the tacho
James, that code reader does do Live data. You can get it to display all sorts like temperature ect.
18 Oct 2013 21:01 #86943 by Rhinoman
Replied by Rhinoman on topic rev counter signal
Did the RPM look OK on that then?
18 Oct 2013 21:40 #86949 by j999pre
Replied by j999pre on topic rev counter signal
I will look again in the morning, cheers people. I'll be back with more info.
Grey pick up Jimny
19 Oct 2013 16:29 #87042 by j999pre
Well I did live data as suggested and the rev counter behaved! No problems. Think I may need to take it on a run, wait for it to play up then read codes and look at the live data.
We will see!
Grey pick up Jimny
  • supergaz
19 Oct 2013 16:47 #87045 by supergaz
Not bad that ebay £20 code reader! It payed for itself when I sorted thiseldo's jimny, told me exactly which lambda sensor was faulty.
  • helijohn
19 Oct 2013 16:52 #87046 by helijohn
Replied by helijohn on topic rev counter signal
supergaz wrote: Not bad that ebay £20 code reader! It payed for itself when I sorted thiseldo's jimny, told me exactly which lambda sensor was faulty.
That's the one for later Jimnys isn't it??
Time to create page: 2.500 seconds
